paint
jf
11-19-2003 13:30:08
where can I get good paint for the farmall. Should it be premixed or not-also what other additives should be in it. What about NAPA, CARQUEST,TSC etc
Farmall Paul
11-21-2003 05:58:32
 Re: paint in reply to jf, 11-19-2003 13:30:08
It all depends on what you want to spend. I wont spray another one of my tractors single stage enamel again. Base coat-clear coat is the most durable and fluid resistant. The very best paint in the wold (in my opinion)is called Standox, but it is also very expensive. Go with PPG or DuPont. I reall am disapointed with the ag stoe paints. If you want a good looking tough finish spray your frame, axles, all the cast stuff with enamel. Then the sheet metal(hood, grill, tank) base-clear. Its more expensive but you'll only do it once. If you have a body shop close you can go in and get a little advice from them. They may cut you a deal to just spay your sheet metal for you. You can find PPG and Dupont tractor codes at Tractor shed.com if I'm not mistaken, there out there. Good pait is expensive but so is doing it again in a few years,good luck and have fun!
TDK
11-19-2003 19:16:31
CASE/IH 2150 is close to origional color & good quality.Check with your local paint supplier for which hardner to use.I use ECONO-BODY Super Gloss #11517.
