can you apply bondo here?
tom
12-03-2003 08:55:33
Hey guys,
I am fixing the hood on a JD MT...near the exhaust pipe it was rusted real back and I had someone cut out the bad spot and re-weld the same heavy gauge steel back in place...the part that was cut-out was 1/2 of the cirle where the exhaust pipe stick through...since that is a REAL HOT area, can you apply bondo here to smooth out the rough spots, then prime and paint?
If the heat destroyed the metal over time, what will it do to bondo? Or, this there a more appropriate material that is great for finishing work and heat resistant, yet holds paint real well?
You you very much for your opinion,
tom
CNKS
12-03-2003 18:32:41
 Re: can you apply bondo here? in reply to tom, 12-03-2003 08:55:33
I can't answer your question, but what I do when I have some question about bondo, i.e., not durable enough, too thick, etc, is to use JB Weld. I fact I did a fix similar to yours on my Farmall Super H. The stuff is hard to sand, but you aren't talking about a very large area. As to the bondo, as long as the exhaust pipe is not in direct contact with the metal, I would think it would be ok. In fact, I think you would burn the paint off first. I used a very thin coat of bondo on top of the JB Weld on my tractor. However, although I have confidence in what I did, I won't guarantee anything, since I have not yet started the tractor. However, I don't expect any problems on mine.
tom
12-03-2003 20:36:32
 Re: Re: can you apply bondo here? in reply to CNKS, 12-03-2003 18:32:41
thanks CNKS...I will keep you posted on what happens so we can keep future posters informed...
i have read many of your posts here and find them interesting...will be posting to you again real soon...
regards,
tom
steve
12-06-2003 19:37:29
 Re: Re: Re: can you apply bondo here? in reply to tom, 12-03-2003 20:36:32
Don't use plain bondo, use marglass its alot tougher then regular body filler and wont crack. The stuff can be purchased from a autobody or parts store. It dries rock hard so try to smooth it out well before you let it dry.
Rich
12-13-2003 20:27:00
 Re: Re: Re: Re: can you apply bondo here? in reply to steve, 12-06-2003 19:37:29
I use a product called all metal that works great in this application . It is a 2 part like bondo and applies similar.I believe its made by USC or something like that.I can get that info if you want.A good paint supplier should know what it is though just by asking for " all metal ".
