Paint removal??
c-case
12-05-2003 15:18:24
I'm getting ready to repaint my fenders. they have a few coats of old chipped paint on them. should this be removed, or just fill in the chips and prime over everything?? thanks
c-case
Jeff
12-14-2003 18:17:00
 Re: Paint removal?? in reply to c-case, 12-05-2003 15:18:24
I would recommend that you sand them off and start with a fresh surface. You will get the best possible surface to paint. Many auto stores now sell aerosol paint stripper that will easily take off old paint in about a half hour.
CNKS
12-05-2003 19:20:57
You will get a much better job if you remove it by sanding, chemical paint stripper, oven cleaner, or some combination of the above. Then use epoxy primer followed by sandable primer surfacer, followed by topcoat.
CNKS
12-06-2003 09:13:52
 Re: Re: Paint removal?? in reply to CNKS, 12-05-2003 19:20:57
Also, no matter how you remove the old paint, sand with no finer than 180 grit before applying the epoxy.
