JD paint polishing
SteveWswMI
12-09-2003 10:50:05
Painted tin work on an M in Sept. when I was done using it. Didnt use hardner. When is is OK to get out the rubbing compound and shine it up a bit?
Dare
12-10-2003 14:16:38
 Re: JD paint polishing in reply to SteveWswMI, 12-09-2003 10:50:05
What kind of paint did you use...synthetic enamel, acrylic enamal, lacquer, urethane? Depending on which one you used, the time varies. Genrally speaking, it will take 30-60 days before you can buff paint with no hardener. This assumes the weather has been 70+ degrees. You will want to be extra careful, because paint with no hardener does not have very good buffing qualities, and you can burn thru the paint very quickly. Hope this helps.
Dare
