JDClooney has gotten me this far. I am in the process of redoing a 420. So far I have taken all tin to bare metal via paint stripper and scraping. I have wire wheeled and scrubbed each peice in Dupont 5717 metal prep, twice. Next I plan to prime with PPG DP90 LF 2 part epoxy, fill the pits sand and prime again then apply color. Questions: Are you supposed to sand this PPG epoxy primer? It says its a non sanding primer. Or do you only sand where you plan to fill pitts and then prime again and sand before finish coats? or no sanding at all? How well does this stuff shoot through a HVLP gun & what size tip is good. Any tips here? I like the late model JD green paint. Does anyone have a reccomendation on what type to use? I need a durable paint, easy to work with for a work tractor that wont chip when it gets smacked by a limb or something. This aint no show tractor but I would like the paint to make it through the years without too much fadeing, it will stay outside. Acrylics, enamels, urathanes... which is the easiest, most durable, easilly had that will go over the PPG epoxy primer. And what will I need to add to it, if anything, so it will shoot, set, shine and last...? All help is appreciated, im a little confused on paint types and additives after reading all the posts. Scott#2
