Hi Almost, Bet you'll be glad when you can change your first name :o). You are correct, the PPG phosphoric acid conditioning products (DX579 and DX520) are not really appropriate in your situation (they are not recommended for cast iron either). Rust Mort, also a phosphoric acid based product, is not appropriate either - at least in my opinion. Those products are intended to be topcoated with something right away. In your case, where you have the metal nice and clean, I would use epoxy primer - a single coat. You don't even need to dirty up a spray gun. Since you are talking reasonably small areas, just mix up a small batch and use a Preval sprayer out of a paper cup. I have even used tablespoons as mixing measures and a 2 ounce bathroom paper cup for this. No clean up to speak of either. That will provide excellent protection until you get ready to do more. You don't even have to finish a part - just prime a done area when you want to quit. Don't worry about the time window with the epoxy. When you are ready to final prime and paint, just scuff "sand" with a coarse Scotchbrite pad, reshoot the epoxy with your regular spray gun and proceed with either a surfacer, if needed, or your topcoat. My current favorite epoxy is PPG OMNI MP170 because of cost. In the past, I have used PPG DP40, the older, leaded, higher-end ($$$) product on clean sheet metal without a topcoat that was always left outside in the rain for ten years without a spec of rust forming. I haven't that kind of experience with the MP170 but suspect it would also be good under such conditions. Rod
