Matco Stud Welder
Slowpoke
01-01-2004 21:37:25
Has anyone used the Matco SS-5150 stud gun? I would like to know if it can use 2.6mm studs. Do stud guns have interchangeable tips for different size pins? I am interested in the one on Ebay #2450964097, but no information is given. Even the Matco site doesn't say much. I thought it would be good for tractor sheet metal.
Harrison
01-16-2004 19:00:16
 Re: Matco Stud Welder in reply to Slowpoke, 01-01-2004 21:37:25
Stud guns are good but we have a set up with three triagle tips that welds it's self to the sheet metal then you pull the built in slide hammer till you get the dent out. Then you simply twist the handle and remove. No stud less time and the tips last forever and they cost like 1.50.The tool costed 525.I'll get the name brand and repost later.Way better deal in the long run them studs add up plus the extra work. Harrison
Slowpoke
01-16-2004 21:36:13
 Re: Re: Matco Stud Welder in reply to Harrison, 01-16-2004 19:00:16
Thanks, I wasn't aware of a tool like that. Will it work on the heavier steel of old tractors?
Slowpoke
01-16-2004 21:35:35
Thanks, I wasn't aware of a tool like that. Will it work on the heaver steel of old tractors?
Slowpoke
01-16-2004 21:23:57
