Scotchbrite pad and sprayer
Ray A
01-21-2004 18:01:53
Two questions - Where do you purchase your Scotchbrite pads used to scuff up primer before painting and do you use course? Second question when using the Preval sprayer, do you clean it up with thinner after use? Thanks, Ray
Bguy
01-22-2004 09:15:09
 Re: Scotchbrite pad and sprayer in reply to Ray A, 01-21-2004 18:01:53
Ray, I have purchased Scotchbrite pads at auto parts stores and hardware stores. I don't think you would need to use a course pad just to scuff up primer. You just want to rough up the surface a little so the paint can bite. I clean up my Preval sprayer's with lacquer thinner if I'm useing paint with hardner. What you clean up with depends on what kind of paint you are using. They usually put clean up instructions on the can.
