2N hood repairs
Gary WV
02-16-2004 16:10:42
Have any of you ever taken the support channel out of a 2N hood? I am trying to decide if it is spot welded to the hood where it makes contact along the length of the hood. I know there are welds where the cross members are but not sure about the remainder. There is a lot of rust behind mine and I know if it is left there the hood will rust through within a couple years.
Rusty Jones
02-24-2004 05:43:51
 Re: 2N hood repairs in reply to Gary WV, 02-16-2004 16:10:42
Say, in case you haven't determined if the reinforcement is welded in or not, here's how to tell! Put a little twist on the reinf. after you get the side edges disconnected from the hood. Assuming the paint is still on the hood, if you twist it a little, forward & back, you can "sight" along the hood, and possibly see little dimples where any spot welds are. If none are seen, ya might have got off lucky! And, by drilling out the spots on the ends of the reinforcement, it may just fall off by itself! Don't drill thru the hood on top, just along the edges! If you have already stripped the hood, spray a little black laquer on the area where you think it may be welded. Then, after it dries, do the test outlined above! Rusty Jones
Gary_N_WV
02-18-2004 02:59:41
Hi Gary...
Just thought I'd let you know that there are 2 Gary's in WV with similar "handles" here on the board.
I have a 46 2N and a couple of Farmalls and stay mostly over on the Farmall Board
Gary
Gary WV
02-21-2004 19:25:50
 Re: Re: 2N hood repairs in reply to Gary_N_WV, 02-18-2004 02:59:41
What part of WV are you located? I am about halfway between Charleston and Huntington in Red House, WV.
Gary_N_WV
02-21-2004 19:54:24
 Re: Re: Re: 2N hood repairs in reply to Gary WV, 02-21-2004 19:25:50
Central WV between Clarksburg and Weston near a small town named "Jane Lew"
Rusty Jones/ The Mower Ma
02-23-2004 20:01:32
 Re: Re: Re: Re: 2N hood repairs in reply to Gary_N_WV, 02-21-2004 19:54:24
Well, now that we have all of your identities arranged, how about answering the guys question! RJ
