Re: Painting Sand Blasted Cast
CNKS
02-20-2004 18:23:06
Do them the same you would do any other prepared metal, use epoxy primer before topcoating. Other than that, I don't consider sandblasted metal to be clean -- I wire brush (gets rid of some of the sand-blasting pits and gives a smoother surface) and actually wash with soap and water, dry with rags to prevent flash rust and immediately coat with Picklex 20, a phosphoric acid-zinc combination to get rid of any escaped flash rust and prevent rust until painting. Although probably not necessary, the Picklex also etches the metal.
