New Sheet Metal prime n paint
Sam MI
02-23-2004 04:26:24
Have several pieces of new sheet metal for my tractors. They come with a black primer on them. Can these pieces be oversprayed with epoxy primer or does what ever the black material is have to be removed? Thanks
CNKS
02-23-2004 17:56:19
 Re: New Sheet Metal prime n paint in reply to Sam MI, 02-23-2004 04:26:24
Do as Butch says and remove it. Or it might remove itself later. I look at most pre-primed parts as rust prevention, and perhaps not very good at that.
Butch
02-23-2004 07:47:16
When I buy repro sheet metal parts I prefer to remove the supplied primer as quite often it is shot over dirt, surface rust and the preservative oils on the metal. Others simply sand and paint it. Take a good look at the parts, if there is any evidence of flaking and dirt under the coating or if it easily flakes off when scraped with a knife you better get rid of it.
