Cost of painting by pro.
Peter
12-24-2001 05:00:01
I was all set to paint my IH 444 this winter with spray bombs until I read this forum. This tractor needs paint, its a working tractor, just want paint on it to preserve it. A local who paints on the side will sand blast and paint this for $375, will have to check on the type paint he intends to use...watercolors? This seems like a really good price, if a pro were to use a decent paint and do all the prep. work whats a fair price?
After reading the forum maybe i should just by a sprayer myself. Your comments are appreciated.
Happy Holidays
santelli
08-06-2003 06:56:45
 Re: Cost of painting by pro. in reply to Peter, 12-24-2001 05:00:01
Bonjour Savez vous le prix d'un tableau de louis almalvy selon ses différentes époques.
Merci
Bruce
01-30-2002 18:34:35
A pro job will cost you at least $1500.00. otherwise, it's not a pro job.
WAYNE WOODRUM
12-31-2001 18:54:40
I PAINT A LOT OF 430 AND 530 CASES IN MY AREA WORKING TRACTORS NOT SHOW TRACTORS I USE DEALER PAINT OR TISCO I STEAM CLEAN AND DO BODY WORK AND PRIMER FOR $400.00 CUSTOMER BUYS PAINT AND DECALS
dab
12-27-2001 08:14:05
Peter,
I agree with the other guys. I'm an ag mechanics teacher (to support my farming habbit) and we paint a lot of stuff with the students. We charge $275 for 40 HP and under, $325 for 41-89 HP, and $450 for anything over plus decals, plus cabs, plus body work (OEM Paint for Case and IH reds, yellows, and Oranges) Sherwin Willaims for everything else. That's pretty much our cost for consumables plus upkeep on equipment. Local body shop who consults with me, charges +$1000 to my prices and that's using OEM paint. Add $200 more for acrylic enamel.
dab
12-27-2001 07:21:31
Peter,
steve
12-24-2001 19:23:42
Pete, thats comparable to what a place like MACO does on small cars. What you get is quick once over with the pressure washer, about an hour of light sanding with a power sander on anything that is in the open, then a coupe coats of basic enamel paint. If you are going for cheap, and it is a field tractor, that might not be a bad option. I had MACO paint a truck several years ago. I did a lot of sanding of the old paint, removed the trim, got all the little nookes and crannies cleaned, then took it to them. IF you spend two days preping (16 hours) at $35 per hour you have saved yourself $500. Those guys are good painters, just not a lot of time spent on prep. It cost them too much. I agree, you might want to ask him about the type of paint. Add some hardener to get it a little tougher. This is definitely 100% better than getting spray cans at Wal Mart and doing it yourself. A pro job is in the $1000. up range.
kealia
05-12-2003 13:52:03
 Re: Re: Cost of painting by pro. in reply to steve, 12-24-2001 19:23:42
I have a 2000 Nissian Altima it is sliver. i wanted to know how much would it cost to paint the whole car? i don't know what you all mean by bodywork, this is my first car. i really need the back of it where the plate located that really need painting, and in the front on the right hand side by my lights, that part really need painting too i would like to know the cost? can you let me know if its cheaper to get certain parts of the car painted ? or is it better to get the whole car painted? please let me know as soon as possible. let me know where your closets locations is in chicago I'll.
thank you,
kealia
Cliff Neubauer
12-24-2001 06:38:50
That sounds dirt cheap to me, almost too cheap. I wouldn't do it for under $1000 and even then I really wouldn't make any money on it. Find out what type of paint he is going to use, it must be pretty cheap stuff but ask if he would use a better paint if you buy it for him. If you can get it painted that cheap it wouldn't make since to invest money in painting equipment unless you have several more to do.
rstara
01-07-2002 20:57:55
 Re: Re: Cost of painting by pro. in reply to Cliff Neubauer, 12-24-2001 06:38:50
I have been repainting all types of tractors for over 12 years. For a quality job his price is to cheap. When you paint tractors you have to spend alot of prep time, for a good quality job, and make sure he is going to remove all of the panels and lights etc before painting other wise its a cheap paint job. DO IT RIGHT OR DON'T DO IT AT ALL. DAVID CITY, NE
