PAINT GUN TIP SIZE
PWB
02-26-2004 10:00:58
I JUST BOUGHT A DEVILBISS FINISHLINE 3 HVLP GRAVITY FEED GUN. IT CAME WITH 1.5 AND 1.8 SIZE TIPS. THE DEALER SIAD I MIGHT WANT A 1.3 SIZE TIP FOR AN EXTRA $25.00, FOR THE TOP COAT. HOW DO I DETERMINE WHAT TIP SIZE TO USE ON MY PROJECT. I'M REPAINTING A VINTAGE TRACTOR AND WILL BE USING PPG PRIMER AND PAINT. THANKS FOR YOUR HELP. PAT
CNKS
02-26-2004 10:10:49
 Re: PAINT GUN TIP SIZE in reply to PWB, 02-26-2004 10:00:58
The PPG spec sheet will give the tip size, 1.5 is OK, but I have heard that 1.3 is better for Omni MTK -- I have a 1.5 and a 1.3, but have not used the 1.3 yet. Use the 1.5 if you use PPG MP 170 primer. For surfacer use the 1.8, the 1.5 will work for sufacer, but you need to add about 5% reducer to the mix--the surfacer is thick. The smaller the tip, the smaller the pattern.
