Air compressor rating
Ray A
12-24-2001 16:58:48
My air compressor is rated 6.2 CFM at 90 PSI and 8.4 at 40 PSI. Does not have a rating listed for 20 PSI. Can anyone tell me what it may be at 20 PSI? Want to know if I can use Finishline II HVLP Paint Gun requiring 11.4 CFM @ 23 PSI. Thanks for any help. Merry Christmas to all.
Franz
12-27-2001 22:12:43
 Re: Air compressor rating in reply to Ray A, 12-24-2001 16:58:48
It will probably have sufficient output, but you are going to need a large diameter hose at low pressure to supply the gun.
Best advice would be to try it out with water or solvent instead of paint.
Ray A
12-29-2001 07:52:43
 Re: Re: Air compressor rating in reply to Franz, 12-27-2001 22:12:43
Found out my compressor is rated 10.6CFM at 20PSI hence it may not work properly on the gun I was going to buy. Thanks for your input I really appreciate your response. May have another question for you later Thanks again Ray
