CNKS
03-04-2004 18:12:07
Re: Question for CNKS in reply to Abe, 03-04-2004 16:46:49
I can't specifically tell you whether or not JD paint is synthetic enamel, it should say on the can. I assume that all tractor store (TSC, etc) and tractor dealer paints are synthetic enamel -- I have no proof. As far as hardener, if JD has hardener use that -- at least you know it is compatible. Synthetic enamels are also known as "fleet" paints, which I believe are used because they are cheaper for a company that does, or has someone do it for them, a lot of painting. That does not mean they are more durable, the opposite is probably true. PPG and other major manufacturers used to have a line of synthetic enamels, I believe some of them are still listed. I think you can get JD green or IH red synthetic enamel premixed from PPG, for example. I do not know if it is better than the dealer paint because I have never used either one. Since I favor Farmall, I have heard that the Case-IH 2150 synthetic enamel works well. However, the acrylic paints, enamel and urethane are better paints, and are usually (not always, I suppose), accompanied by a full line of products, such as primers, surfacers, and hardeners, that are compatible with them. If you want a fast paint job, one where you only use primer and topcoat, then use tractor dealer paint. If you intend to spend most of your time cleaning, removing dents, and preparing your tractor prior to painting, don't try to save a few dollars on paint -- use a major line of paint such as PPG or DuPont. Rod, Butch, or some person more knowlegeble than me, bail me out of this, or else set me straight! I only repeat what I have been told (the painting I have been told about has worked so far).
