Sealer
Dave R (MN)
03-10-2004 23:20:58
After you are done sanding the surfacer primer do you have to seal it with a sealer primer before you paint? If so is epoxy primer a good sealer? Thanks.
Gene B
03-11-2004 19:13:12
 Re: Sealer in reply to Dave R (MN), 03-10-2004 23:20:58
No you don't have to. It just depends on how high a quality of job you want and how much you want to spend. Epoxy primer is the best for durability and is a great sealer. Be sure to final wet sand everything whether you seal or not with 600 grit until smooth or your paint will have the sealer texture look ruining the paint job. The wet sanding will make the difference between an average finish or a dazzling deep gloss wet look finish.
