buffing question -car
mudstuck-
03-11-2004 07:44:41
sorry to bother you fellas, but dont know who else to ask. i hit a new toyota car this morning. i scrubbed up against it. no dents. just a few minor scratchs through the clear coat. the owner will let me fix it and avoid the insurance company. can new car clear coats be buffed out and then waxed up good? sure could use your help.
mudstuck
CNKS
03-11-2004 19:14:39
 Re: buffing question -car in reply to mudstuck-, 03-11-2004 07:44:41
If the scratch is all the way through the clear coat, no. If it is shallow, maybe -- you probably will not get rid of the scratch to it's entire depth, without danger of going through the clear coat. That is one (perhaps the only) disadvantage of the BC/CC system. With the old laquers or enamels, you could polish out about any scratch that had not reached the primer.
Gene B
03-11-2004 19:05:07
Sure you can buff clear coat but you might not need to. I repair a lot of those type scuffs on friends cars by using 3M Polish/Wax. I can't remember the part number but it's available at any good parts store. Comes in a black squeeze bottle. This stuff when applied with a soft towel can polish out and hide those types of scuffs and scrapes quite quickly. If you left a lot of your paint on finish it might take several applications.
Good Luck!
Gene
Gene B
03-11-2004 19:22:25
 Re: Re: buffing question -car in reply to Gene B, 03-11-2004 19:05:07
True CNKS, if the scratch is all the way to the base coat or primer, polish won't save it. A good painter can usually spot blend the area easily without it costing too much.
