Manifold paint....
Stan(PA)
03-19-2004 10:49:24
What type coating will hold up on a manifold? Do these "Hi-Temp" paints actually hold up? What do you guys use? Thanks....Stan
Mike S
03-19-2004 22:40:59
 Re: Manifold paint.... in reply to Stan(PA), 03-19-2004 10:49:24
Go buy some John deere manifold black paint at the dealer ,I have excellent luck with it.
Stan(PA)
03-19-2004 13:12:28
Thanks guys! I just got a new manifold, and want to paint it before I install. Thanks again...Stan
CNKS
03-19-2004 13:00:03
My opinion--The manifold was painted with the same paint as the rest of the tractor. It burns off. I paint mine, but it's mostly just to cover the intake part of it (Farmall). It then burns off the exhaust part -- I kind of like it that way -- only my opinion.
Butch
03-19-2004 12:25:50
No paint wil hold up for long on a manifold that gets hot as with a tractor that is worked some. For parade and show units Eastwood makes a decent coating that is availible in a gray cast like color. If black suits you barbique grill paint is cheap and holds up as good as anything I have tried. There are industrial coatings that will hold up on a manifold, at least people have posted that they do. They are expensive and you must send the manifold to them for coating. Try a search of this forum, cant remember for sure where I read it, might be over on restoration tips.
