steering wheel
Ron Grother
03-20-2004 16:36:33
I have a oliver60 wheel with lots of cracks will bondo work and what would be agood paint
Dan in Pa
03-27-2004 17:09:23
 Re: steering wheel in reply to Ron Grother, 03-20-2004 16:36:33
Ron, I have good results using a product called Fast weld - epoxy putty. It sells in a round tube, you break off what you need and mix in the palm of your hand and apply. You have about 10 minutes to work with it before it starts to set up. You do a little shaping and then sanding and paint. I have repaired quite a few badly cracked steering wheels this way.
Gene B
03-23-2004 17:11:55
Hi Ron
Yes, bondo will work fine to re-smooth the wheel. I think icing glaze filler 'really thin bondo the consistancy of pancake batter, keeps pinholes to a minimum if any' would be easier to work. It's available at all quality parts stores. Do your intitial shaping with 80 grit then reapply another thin coat and final shape and smooth with 180 grit. Prime with a spray can of NAPA 7220 self etching primer,$5 a can, spray about 3 or 4 coats and let dry overnight. Wet sand the next day with 600 grit until smooth. Then also at NAPA get a spray can of their semi gloss satin spray paint, also about $5.
Should look great when finished and last a long time.
Good Luck!
