Spray gun
Dan in Pa
03-20-2004 17:31:30
I finally made up my mind to switch to a HVLP gravity spray gun. I am thinking of the Sharpe-Platinum . I was just wondering if anyone has any comments, good or bad, on Sharpe hvlp guns.
Cliff Neubauer
03-21-2004 16:36:29
 Re: Spray gun in reply to Dan in Pa, 03-20-2004 17:31:30
I've had a Platinum with the 1.3 tip and 3000 air cap for almost three years and I love it. I've used it to spray epoxy primer and primer surfacer and while it wasn't very fast it did the job, I've since bought a cheap gun for primer to save the Platinum for topcoats. At the suggestion I read on another forum I usually turn my inlet pressure up to 55 psi instead of the 50 psi that Sharpe recremends and it will lay down single stage urethane paints as smooth as glass. I'd guess that I've ran 15 gallons of paint through my Platinum so far without a single problem.
Henry joyce
03-23-2004 06:33:10
 Re: Re: Spray gun in reply to Cliff Neubauer, 03-21-2004 16:36:29
Hello
Is an electric spray gun,good enough to get an acceptable finish on a atractor body?
CNKS
03-23-2004 07:55:49
 Re: Re: Re: Spray gun in reply to Henry joyce, 03-23-2004 06:33:10
If you are talking about the airless guns, those are made for houses, not automotive applications, the atomization will be poor -- probably better than a brush, though!
CNKS
03-20-2004 18:14:22
I have one -- don't think there are any bad comments. Excellent gun.
Gene B
03-23-2004 14:42:04
 Re: Re: Spray gun in reply to CNKS, 03-20-2004 18:14:22
I've been using a Sharpe 975 HVLP w/pressure cup for about 6 or 7 years. Wouldn't use anything else now given the reliability and finish quality of this gun. I used to use an Accu-Spray system which was great but was too expensive to maintain.
