Paint remover vs sandblasting
Tom in Missouri
03-28-2004 17:42:20
I want to repaint my Ford 8N and was wondering if I should have the old paint sand blasted off or use a paint remvoer. I am not going to do it all at once, just a couple parts at a time as I get time. Would I be better off taking the parts and having them sandblasted or use paint remover? I don't have a lot of problem with rust. Thanks.
49 Cubber!
03-30-2004 16:59:50
 Re: Paint remover vs sandblasting in reply to Tom in Missouri, 03-28-2004 17:42:20
When I did my Cub I used a marine grade stripper.On anything Icould take off and wouldnt be getting inside the engine or tranny I had sandbalsted.I think all together I spent maybe 40 bucks on blasing and 40 on stripper,but I still have a half of a gallon of stripper left.I just brushed it on heavy and let it sit for a couple of hours in thr shader the hit it wit hmy pressure washer.
Joe Evans
03-29-2004 13:59:36
I would do both. Let the paint remover do the softening up work and bulk removal. Then follow up with a quick dusting of blast sand.
Sandblasting is a PIA, but it simply cannot be beaten for a total bare metal starting point. Minimize the sandblasting by using the remover first.
Tom in Missouri
03-30-2004 05:21:39
 Re: Re: Paint remover vs sandblasting in reply to Joe Evans, 03-29-2004 13:59:36
Joe,
Thanks for you comments. Can you recommend a good paint remover to start with?
Joe Evans
03-30-2004 08:29:07
 Re: Re: Re: Paint remover vs sandblasting in reply to Tom in Missouri, 03-30-2004 05:21:39
There's a thread on Red Power that will help you out.
