rear rim
Ron Grother
04-04-2004 16:13:37
bough a used rim for my cockshutt 80 had a hole in it from calcium had it beed blasted then powder coated. had it painted it look great looked at it the other day thier were to good size blisters what did I do wrong
Butch
04-05-2004 10:14:52
 Re: rear rim in reply to Ron Grother, 04-04-2004 16:13:37
Once it gets on a surface calcium is real hard to get completely rid off, especialy a surface that is pitted. I'd guess you blew part of the calcium back onto the cleaned areas when blasting, I have had the same thing happen as you did. Now I wash rims with strong detergent soultion before blasting then again after. The cleaning will cause some surface rust to form and I re-blast myself but you could probably used muratic acid or other rust remover for this step. I would like to find something to nutrualize (spelling?)the calcium. Anybody have an idea for that? I am not much at home chemistry.
