How to clean off body-filler?
KCTractors
04-25-2004 09:53:42
I screwed up yesterday! I did not read the directions right when mixing the body-filler. I wanted to fill some cracks on a steering wheel. I did not put enough activator in the filler and it did not get hard. It was to be 12 drops to a golf ball size filler and I only put in 2 drops. My question is: What can I use to wash off the filler with? It is a product called Metal To Metal filler. I shouldn't of had that beer before I read the directions!
Rusty Jones
04-29-2004 20:36:15
 Re: How to clean off body-filler? in reply to KCTractors, 04-25-2004 09:53:42
Well, scrape off all of the filler as best you can, then try wiping it off with lacquer thinner, using a stiff brush to get into the crevices. Let it dry up, then do it right next time. And remember: When all else fails--read the directions before doing anything! Helps a lot! RJ
