Hi John, Well, I guess we just disagree about the OMNI. I have had excellent luck with it (MTK and MC). Same goes for the OMNI epoxy primer and their surfacer. I have only heard others complain about coverage with the OMNI MBC. I don't do bc/cc so that doesn't concern me. I find the MTK coverage to be very good. I typically use 3 coats but certainly could get by with the 2 minimum recommended on the tech sheet. That agrees nicely with the 3 coats recommended for the higher priced Centari AE and the 2-3 coats recommended for the higher priced Delstar AE. I also always used 3 coats when using either the Centari or the Delstar. So my own experience, although more limited with the OMNI, simply doesn't bear out the "twice as much paint" claim. Perhaps there could be an issue with coverage depending on color or uniformity of the substrate? I always put my color coat on a totally even-colored base, usually the grey epoxy or the grayish tan of the surfacer. My experience with the OMNI has been only with orange on both of those so I can't confirm good coverage with other topcoat colors or non-uniform substrates. I don't do metallics anymore so I can't address that possible factor either. I also have not had a problem with drying that you mention. The MTK is always dry to the touch in just a few hours - no worse than others I have used, and the MC clear can be handled easily in a couple of hours. I simply have not had any problem or complaint at all with drying. Componding is not an issue with me either. I assume when you say polish that you really mean compounding. As Butch says, such a refinement in surface finish is not practical for most tractor work. Perhaps the hood and fenders maybe...but if you have to go to that effort to obtain an acceptable finish, you are either doing something wrong or you are treating a tractor like that Mercedes I occasionally bring up. Actually, I have seen some single stage non-compounded finishes that would be suitable for a Mercedes but then again maybe I please too easily. Poor gloss retention? Well, I have one of my tractors outside that was done two years ago in MTK and the gloss and color shade is just as fine as the day it was sprayed. It is never housed so sees the NH weather outside continuously in all seasons. I'll have to reserve judgement for times exceeding two years but I guess I will find out if poor gloss retention (relatively) is a valid complaint. Worst smell? I am not into siffing paints so I can't say :o). I don't recall it being any "worse" than Centari or Delstar. All the four or five different hardeners that I have had the displeasure of smelling have a rather obnoxious odor to them. Worse than the paint with no hardener. In any event, after mixing I am inside a fresh air mask so smell is not a factor for me. As far as other manufacturers are concerned, I only have three available in my local area. DuPont, PPG and Martin Senour. I have no experience with the MS lines. My past intermittent experience over 30 years has been with DuPont's Centari and PPG's Delstar. I have been using OMNI, along with some Centari for the past two-three years. I have not tried the NASON line in DuPont. I guess I would have to have a future poor experience with the OMNI that I attributed to the paint for me to bother to try a different product line since I have a small investment in different temperature reducers and hardeners that are specific to it. Thanks for your comments but I just can't agree with your "anybody but OMNI" putdown. I know the high-enders will look down on most "economy" lines as do the bc/cc crowd with AE. That's life and expected. I am pleased with OMNI for the price and have no reason yet to look elsewhere. Rod
