Saving Decals
Wayne M Kittler
05-07-2004 18:33:59
Is there any trick to painting equipment while saving the original decals on the machine ?
Gene B
05-08-2004 17:14:50
 Re: Saving Decals in reply to Wayne M Kittler, 05-07-2004 18:33:59
Wayne, It is sometimes desirable to save decals and in such cases you'll need to mask the decal with 3M Green masking tape and use a razor blade to trim the tape from the edges of the decal.
Take your time a do a good clean job while trimming the tape from the decal. Depending on how many coats of paint you gave it, you might need to trim the edges so the tape will pull cleanly away from the decal.
The only times I've saved decals is on new or newer equipment that requires a color change from original the original colors such as highway equipment that I have to paint Omaha Orange.
johneodeere
05-12-2004 14:41:16
 Re: Re: Saving Decals in reply to Gene B, 05-08-2004 17:14:50
I have masked and saved decals on my old case and it worked out rather well although they were square and very easy to mask.
