SPRAY PAINTING/ WATER FILTER?
AWC
05-11-2004 08:08:21
IF I AM SPRAY PAINTING A TRACTOR, DO I HAVE TO HAVE A WATER FILTER SOMEWHERE ALONG THE HOOKUP OR CAN I SKIP THIS? IF NOT, HOW MUCH MONEY WILL IT COST AND HOW IS IT HOOKED UP? THANK YOU.
Barr
05-17-2004 06:48:17
 Re: SPRAY PAINTING/ WATER FILTER? in reply to AWC, 05-11-2004 08:08:21
Both previous posts offer good advise. Here's my thoughts.
Filter requirements depend on a number of factors.
1. Do you want the paint flawless or decent?
2. How much water is in your tank? You do drain it faithfully every day - right?
3. How long does it run - a small compressor will run more than a big one. The more it runs, the more water you'll get. Relavent, is also weather you use a HVLP gun or not. The High Volume Low Pressure gun will use more air - thereby introducing more water to your tank (HVLP guns are much better overall).
4. You can spend as much money as you want TRYING to get dry air, spend no more than you need to and can afford.
5. The $25 air dryer from Harbor Freight are OK - dont expect them to last or work very well. They do however take some water out.
6. Definately, go to a automotive paint store and buy the $3 plastic inline filter and put it on your gun.
I have painted many street cars, race cars, and other items with very good results using common compressor knowledge and $30 worth of air dryer tools.
Good luck,
Barr
Jerry B
05-12-2004 06:24:25
I use 3 "filters" to remove water from the system.
The first is a water/air seperator made from a drive shaft. The air enters near the middle of the shaft. The bottom of the shaft has a drain valve to remove the water. At the top of the drive shaft is the air outlet to the rest of the system.
Down stream from the seperator I have a paper filter that uses toliet paper for a flitering element. It gets changed every few months or just before any major painting.
Attached to a quick fitting is my regulator/filter assembley. This quick attachment method allows me to move it from place to place, connect to another airline and not have to drag around a lot of hose to stir up dirt and debris.
JHD
04-20-2005 13:41:45
 Re: Re: SPRAY PAINTING/ WATER FILTER? in reply to Jerry B, 05-12-2004 06:24:25
Jerry can you give me some info on the toliet paper filter, pics where to get one or how you made that one? Thanks.
CNKS
05-11-2004 14:37:52
The answer to this is buried somewhere in the replies to D. Mac, below. Mine cost about $100, it works fine. There are better ones. My compressor is fairly new and has been taken care of. You may or may not need a better filter. The brand name of mine is "Steath", I believe. The further away from the compressor you put it the better -- I don't remember the correct "minimum" distance. Mine is about 70 feet. Don't skip that step.
