HOW MUCH PAINT DO I BUY?
AWC
05-11-2004 08:12:36
I AM GOING TO BE SPRAY PAINTING AN UNSTYLED 1935 ALLIS WC. HOW MUCH PAINT WILL I NEED TO PURCHASE AND HOW MANY COATS WILL I NEED TO LAY DOWN? I HAVE A GRAVITY FEED HVLP GUN AND PLAN ON USING PPG PAINT? ALSO HOW MUCH PRIMER WILL I NEED AND HOW MANY COATS? THANK YOU.
Butch
05-11-2004 18:55:30
 Re: HOW MUCH PAINT DO I BUY? in reply to AWC, 05-11-2004 08:12:36
If you look down the page just a bit there is a pic of a WD I did with OMNI under a post about gloss. The tractor was partialy dissasembled. The frame rails were off and a couple coats went on the back of them plus the sides of the castings they cover. Then they were installed and the the powertrain got pretty much got three coats, its hard for me to keep track when squirting paint under, over and around all those parts. Sheet metal, fuel tank and wheels were done afterwards with three coats. With OMNI MTK and my Astro HVLP the whole job took just two quarts. A splash job over an assembled tractor would take less. Technique and equipment means a lot, I'd buy a gallon and have plenty in case of a screw up or matching paint for a implement or touch ups.
