Use primer sealer or just paint
David
05-25-2004 15:17:45
After useing Western RS 4201 Acrylic primer surfacer should I use a primer sealer, or just blow the paint on? At my paint store one guy said to use a sealer, while the other said not to. I think I have read on this site that I need to use a primer sealer. If I use the primer sealer which one should I use?
Thanks in advance for the help on this question and all the others in the past.
CNKS
05-26-2004 17:57:03
 Re: Use primer sealer or just paint in reply to David, 05-25-2004 15:17:45
I don't think you read on this site to use a sealer over a surfacer, unless for some reason you mix brands of paint. It is best to stick with one brand and do what the manufactuer recommends. I think for acrylic laquer, a sealer was recommended over certain surfacers, but those days should be gone. Do as Butch says and contact the manufacturer,perhaps they have a web site.
Butch
05-26-2004 17:31:33
I am not familiar with Western paint but in the PPG lines a sealer would go on first. As the name implys it seals the new paint from bleeding from anything underneath. What PPG terms a surfacer would be applied wherever block sanding needed to be done for an even surface such as sheetmetal. I would not reccomend a surfacer be used on castings or other parts that would be left rough for final paint. Might not hurt anything but does nothing for the integrity of the paint job. In PPGs line the pure sealers have been largely replaced by epoxy primers which are capible of both priming and sealing. I would contact Western and get the straight scoop if it were me.
