Thinner
Paul
01-07-2002 05:08:09
I had some parts that I wanted to prime yesterday. My Rustolem primer instructions said to use acetone to thin with. I didn't have acetone so I used mineral spirits. It applied well and seems to be holding well. Did I screw up when I did this?
Thanks in advance!
Terry-n-Mo
01-07-2002 16:16:43
 Re: Thinner in reply to Paul, 01-07-2002 05:08:09
Paul, i did the very same thing a few weeks ago before it got cold. I used rustoleum and mineral spirits for thinner and seemed to turn out fine. This was on an ole finish mower.
Eric Rosenthal
01-07-2002 15:30:26
Acetone is very fast evaporating. Mineral spirts will be fine for what you did. A recent EPA ruling also has granted exemption to acetone because it does not contribute to the problems associated with photochemical smog. Acetone is now considerd a non-VOC so it can be freely used as a paint thinner and is not subject to regulation. Many industrial and auto paint manufacturers have adopted it use for this purpose. I don't agree with what Rustoleum has done by recommending it though. Acetone has a flash point of Zero degrees F and is one of the most dangerous items you can put in the hands of a consumer.
LanceM
01-07-2002 08:10:59
I think the big differance is that the actone would flash off faster and give you a quicker dry time.
Paul
01-07-2002 17:55:10
 Re: Re: Thinner in reply to LanceM, 01-07-2002 08:10:59
Thanks guys! I feel much better now! The paint job seems to have turned out fine.
Paul
