New tool
sykes
01-07-2002 15:32:46
I have a pistol grip air grinder which is very common and easy to find. If you buy an adaptor kit for Matco, you can use some great products from 3M. One is the standard 3in. Roloc sanding and grinding wheel and the other is a new rubber stripping wheel. The new wheel has hundreds of rubber studs that strip paint as fast as a grinder. What is so special about this is that it does not remove or scar any sheet metal. This is the best thing for sheet metal stripping Ihave found lately.
brandon
01-16-2002 09:35:47
 Re: new tool in reply to sykes, 01-07-2002 15:32:46
where did you get the rubber wheel used to remove paint? how much?
thanks
brandon
01-16-2002 09:33:22
thanks
