Arm Hammer wash powder to help remove stuck pistons?
JK
01-07-2002 18:57:06
Has anyone out there tried using the Arm & Hammer washing powder in solution to remove the rust to allow removal of pistons stuck in sleeves or removable jugs? If so how did it work?
John
Ed Shelton
01-11-2002 06:11:15
 Re: Arm Hammer wash powder to help remove stuck pistons? in reply to JK, 01-07-2002 18:57:06
This should work just fine. I used it to remove rust from inside the water pump pully on my JD 440 - I let it work for 3 days and was able to pull the pully off and rebuild the pump. I,m sold on this process. It just removes the rust. Did not affect the press fit at all. Thanks Ed.
olen
01-10-2002 06:16:01
jk look under evapo-rust.com for a product that is water based that i have used to free up rusted pistons in my farmall c ,it's new on the market,take a look at the info on it . good luck
Franz
01-07-2002 22:02:42
Read the postings on Electrolytic Derusting and rust removal.
It has been done on several hit & miss engines, and it helps a lot.
JK
01-08-2002 18:26:15
 Re: Re: Arm Hammer wash powder to help remove stuck pistons? in reply to Franz, 01-07-2002 22:02:42
Franz,
I have read the previous posts on derusting using this method but wondered if would work for a piston/sleeve or piston/jug assembly since the derusting would have to take place inside the cylinder instead of on the outside as when doing a piece of sheet metal etc. I would assume it would help to figure out some way to position the scap metal inside the cyl without touching the piston or cyl wall like maybe a piece of rubber wraped around the inside of cyl?
Thank you for your reply
John
Doc
01-07-2002 21:39:44
This is a new one. I am all in favor of trying new things, but in this case I would stick to PB Blaster or Marvel Mystery Oil. I suppose there could be some type of chemical reaction between the baking soda and rust, but the old ways have proven themselves many times over. If you try it and it works, let us know. Doc
