8N seat
Jim
10-11-2001 19:17:27
I would like to repaint the seat on my 8N it is very rusty and badly pitted. Where do I start?
sammy the RED
10-12-2001 07:40:16
 Re: 8N seat in reply to Jim, 10-11-2001 19:17:27
I painted my uncles 8-N a couple of years back.
I used a wire brush and sandpaper to take it down to bare metal. Than I primed and top coated it.
Jim
10-12-2001 12:01:26
 Re: Re: 8N seat in reply to sammy the RED, 10-12-2001 07:40:16
The main problem is the deep and wide pits. I was wondering if bondo would work to fill these and smooth out the pits. Having never used bondo before, would I Have to be down to bare metal? Could I do this with chemicals?// Thanks alot.
Tim
10-12-2001 13:36:17
 Re: Re: Re: 8N seat in reply to Jim, 10-12-2001 12:01:26
Check out the website evapo-rust.com for your chemical rust remover. As far as filling the pits, try glazing putty,it comes in a tube, you squeeze it out and spread it with a plastic spreader or putty knife and sand it when it cures. You can even buy it at Wal-Mart in the auto section. Good Luck
Chrisr
10-12-2001 15:25:57
 Re: Re: Re: Re: 8N seat in reply to Tim, 10-12-2001 13:36:17
You can buy a filler that comes in a tube that auto body guys call "icing". Any part store has it. works great for large pits.
Kens640
12-11-2003 12:48:16
 Re: Re: Re: Re: Re: 8N seat in reply to Chrisr, 10-12-2001 15:25:57
Chrisr , the stuff in the tubes is called Glazing putty . It's actually extremely thick primer which works best after the metal has been cleaned down & primed first . Then you spread this putty into the little indents & let dry for awhile . Then sand smooth with 400 grit or finer . Then prime the whole thing again before the final finish is applied . Ken
