SYNTHETIC ENAMIL
FRANK
06-08-2004 16:31:01
ICKED UP MY JOHN DEERAY AND WAS SHOCKED IT IS SYNTHETIC> IS THIS ALL JD MAKES NOW? and is this a good paint.do i need a hardener for synthetic paint.any help appreciated.
TDK
06-09-2004 10:41:20
 Re: SYNTHETIC ENAMIL in reply to FRANK, 06-08-2004 16:31:01
I believe the number is 15117.
Adam Paul
06-08-2004 18:03:42
Yep, it's synthetic. And yep, you should use hardener. I bought some JD yellow and green to mix for a David Bradley I was working on, and it literally took monthes to dry. I got some good advise here on this forum... Use some hardener with it. I like the paint to be shiny, so I went with a NAPA hardener; a number like 51117 I think. But then you have to worry about the ISO's...
Hope that helps,
Adam
Gene B
06-10-2004 19:40:37
 Re: Re: SYNTHETIC ENAMIL in reply to Adam Paul, 06-08-2004 18:03:42
For that NAPA brand synthetic enamel hardener you'll need part # 15118. The 15115 and 15117 (117 is super high gloss but I can't tell a difference between it and the 115, are for Acrylics.
Good luck!
