Rattle Cans?
Ron F.
06-17-2004 21:41:55
Hi all, I will be restoring my first tractor this summer, a 36 B JD, I plan to have the hood pro done at a body shop, but I was wondering if I can use a rattle can to paint the smaller parts (fan, fly wheel, ect.) as I get them clean and ready for paint? I repainted a 111 JD lawn tractor with them and had real good luck on the hood and fenders. I used TY6541 with a fan spray from the local JD dealer, That was 5 years ago and it still shines nice and waxes good (no green on the wax rag) it is stored inside and used to mow and blow snow. The B will also be stored in side and only paraded Any input will be greatful, Thanks from Minn.
bob
06-21-2004 19:49:29
 Re: Rattle Cans? in reply to Ron F., 06-17-2004 21:41:55
Two things; I set the cans in a pan of very warm water and warm the paint up.It gives the propellent more umph amd makes the paint go on a lot smoother and then be sure to SHAKE ,SHAKE,SHAKE.That breaks up any pigment that is stuck together inside the can.
Ron F
06-21-2004 21:42:38
 Re: Re: Rattle Cans? in reply to bob, 06-21-2004 19:49:29
Thanks for the info about the water! Do you use them or spray all parts with a gun. I am wondering about paint quality too?
bob
06-22-2004 18:20:55
 Re: Re: Re: Rattle Cans? in reply to Ron F, 06-21-2004 21:42:38
Some of both.I'll use a gun on most jobs but for small stuff and sometimes for touchup I'll use a bomb.If its done right is is impossible to tell if it is a gun or a bomb job.
