rustoleum for cub cadet
sol
06-22-2004 14:16:56
Does anyone know if rustoleum makes any paint that is close to cub cadet yellow?
Rusty Jones/ The Mower Ma
06-23-2004 15:31:14
 Re: rustoleum for cub cadet in reply to sol, 06-22-2004 14:16:56
Yes, Rustoleum does have a nice yellow, and a white, that are fairly close to Cub Cadet colors. If you are going to spray paint them, get some Valspar reducer to thin the paint for spraying! I just redid a Cub Cadet set of fenders and the hood, etc, It turned out pretty good. The colors were very close, and if yer painting everything, and aren't a purist, the colors will be o.k.! now, i say the job turned out good, because i have 45 years of practice painting cars, but, take yer time, don't load the paint on too quickly, give each coat time to "tack" up, before you apply the next coat! To check for correct "tack-up", touch a knuckle to the paint lightly, to see if it is ready for another coat. runny, or wet, wait!--sticky-- go with another coat! Good luck! RJ
sol
06-23-2004 19:20:58
 Re: Re: rustoleum for cub cadet in reply to Rusty Jones/ The Mower Ma, 06-23-2004 15:31:14
Thanks for the good info. Do you recall the name of the yellow that you used?
sol
06-23-2004 19:13:16
07-02-2004 19:36:02
 Re: Re: Re: rustoleum for cub cadet in reply to sol, 06-23-2004 19:13:16
I think the yellow was named: "Sunshine yellow", and the white had a slight gray cast to it. i'll get the names tomorrow. Rusty
