CNKS
06-26-2004 14:12:54
Re: Looking for Help with Spray Gun Adjustments in reply to Paul_NJ, 06-25-2004 21:04:48
I agree with Rod. But, I have "thinned" 182 with the same reducer that I use with the topcoat -- it does help some, but as Rod says it is probably more your gun adjustments and technique. Don't thin more than 5%. Meaning, to a quart of the finished product (946 ml), add 5% or 47 ml of reducer. Also the spec sheet for 182 will say something to the effect when using 182 on bare metal: Properly sanded AND etch primed steel. MUCH simpler to use 170 epoxy primer, which bonds to the metal much better. As Rod said, put the 182 over the epoxy on the sheet metal, you don't need 182 on the cast. What is a "Wagner 3 stage gun? --Is this an automotive unit? Or for painting houses, etc. The tip size (see P-sheet) for 182 is supposed to be 1.6-1.8 mm, my gun has a 1.5 as I consider 1.8 to be far too large. For most HVLP guns (don't know if this applies to yours or not), for a full pattern, with the gun empty: Turn the fluid control almost all the way out, pull the trigger, and turn in until resistance is felt, turn in 1/2 turn more. Fan pattern is set at about 1/4 turn in from wide open. You can, of course, set the pattern any width you want, as long as you keep the fluid and air in balance, but most guns operate best with a full pattern. The 6 psi is tip pressure, most are more like 10. The pressure is set at the INLET of the gun and is reduced to the correct psi in the gun. The gun should say what the inlet pressure is to achive the correct tip pressure -- probably in the neighborhood of 40-50 psi. That pressure is set with a gauge on the gun, by adjusting the regulator on the wall.
