sanding primer
john
06-26-2004 07:15:15
I have a question. Is it possible to sand primer to smoth for paint to stick the way it should?
My son wanted to get a good slick finish on a tractor hood. We wet sanded the primer with 1200 grit paper. The hood came out slick. When he put the paint on he got a real good paint job but after a few min. the paint started to sag. it does not have a run like to much paint just a sag in the paint and looks like it is to thick? Any advise would be appriciated. Thanks John.
Jason(PA)
07-02-2004 19:01:54
 Re: sanding primer in reply to john, 06-26-2004 07:15:15
What was the temprature like the day you painted? That same thing can happen when the surface you are painting is too cold.
john
07-05-2004 12:57:06
 Re: Re: sanding primer in reply to Jason(PA), 07-02-2004 19:01:54
The tempature was about 75 to 78. I have sanded and repainted the metal and it looks better. I used a 500 grit paper to get the finish back to the ready to paint stage. I still have the rest of the hood to shoot. I am painting a green and yellow hood.
