Putting It All Back Together
Paul_NJ
06-27-2004 17:21:08
I haven't seen this question asked, but I've been wondering about how I was going to finish from the time I started unbolting components 2 years ago. I'm reconditioning a 51 Farmall Cub. Everything has been taken apart, cleaned, stripped, and primed. New seals, gaskets, brakes, etc. Everything is removed down to the engine block, bell housing, and trans, which is up on blocks. Priming was accomplished in my garage in half a dozen batches with parts hanging from coat hanger wire hooks, chains, you name it.
My question is: what is the best way to topcoat? I roughly contemplated I'd paint batches of the individual parts with several coats, using the hangers and chains again. But should I assemble only after all the topcoating is done (touchup the bolt heads individually) , or shoot a couple coats of topcoat, reassemble, and topcoat the whole thing one more time? How do you guys do this?
I'm planning to use OMNI 2K urethane. How many coats would you recommend? Any thoughts would be appreciated.
Hopefully I'll get my priming/painting technique straightened out first. This board has been a great help. Thanks
Butch
06-29-2004 18:24:50
 Re: Putting It All Back Together in reply to Paul_NJ, 06-27-2004 17:21:08
When I paint a tractor I like to have the base castings as much together as I can and still coat everything. Before I add parts I mock them up to check, sometimes if it is a part that would be hard to install without scratching it or something else, but also hard to paint on the tractor I will paint the back side of the part and what ever it hides from being painted and install it just before I paint everything. I do end up with quite a few parts hung on wires etc to be installed later. Yes you can paint the bolt heads with a fine brush. A couple coats and nobody will know, it's just a whole lot of work Id rather not do if I can get around it. Sheetmetal is always painted seperately. How namy coats you will need depends on your technique, gun and your underlayment color. I have gotton by nicely with 2 coats on some and never used more than three with OMNI MTK.
