Is sanding epoxy necessary for . . .
RJ
06-29-2004 16:45:17
I have put down Omni 170 Epoxy Primer, now plan to lay down 181 surfacer. Do I need to scuff or sand the epoxy primer at all before I lay down the surfacer as long as I stay within my re-coat window?? Your help is greatly aprreciated!
Butch
06-29-2004 18:35:26
 Re: Is sanding epoxy necessary for . . . in reply to RJ, 06-29-2004 16:45:17
I like the 170 to be good and hard before I work with the surfacers so mine sits a day of two before the surfacer is used, that's just my personal preference. I scuff with Scotchbright before the first coat of 181. There is no recoat window for the 181 so you can take your time there. After the 181 I have recoated with 170 just before painting but I have also top coated right over the 181. My oldest OMNI job is right at 4 years old now and the top coat was put right over the 181. There is no signs of lifting. For reasons unknown, lately I have been recoating the 181 with 170 just before the topcoats are put on. I guess it falls under the cant hurt and might help catagory.
RJ
06-29-2004 19:38:58
 Re: Re: Is sanding epoxy necessary for . . . in reply to Butch, 06-29-2004 18:35:26
Thanks Butch for that info. So the 170 lays down smooth enough for the top coat to go on sheet metal? Or do you sand the epoxy some before you top coat sheet metal? It's my understanding the epoxy sands hard? Your help is very much appreciated.
