HOW SHOULD I WASH PARTS?
AWC
07-06-2004 16:35:15
HOW SHOULD I "WASH" PARTS, THAT WERE CLEANED W/ CLEANERS, PAINT REMOVERS AND OTHER CHEMICALS. IF I DO NOTHING, WILL THE RESIDUE LEFT BEHIND FROM THESE PRODUCTS AFFECT PAINT ADHESION? WHAT IS THE FINAL METAL PREP STEP BEFORE BEGINNING THE PAINT PROCESS? THANK YOU AGAIN.
CNKS
07-06-2004 17:40:32
 Re: HOW SHOULD I WASH PARTS? in reply to AWC, 07-06-2004 16:35:15
A wax and grease remover such as PPG DX330. Apply and wipe off until the rag is clean. Do not let it dry on the metal. Follow with a tack rag.
Chester
07-07-2004 15:41:02
 Re: Re: HOW SHOULD I WASH PARTS? in reply to CNKS, 07-06-2004 17:40:32
Gas does an excellent job.....just be very careful using it. Sounds crazy but it does work. Fifty years back, working P/T in a body shop, that was their final wipe down before spraying cars. Have used it since in all my metal painting projects. Use care!!
CNKS
07-07-2004 17:45:40
 Re: Re: Re: HOW SHOULD I WASH PARTS? in reply to Chester, 07-07-2004 15:41:02
There are better products than gasoline. It leaves a residue that may or may not be compatible with the better paints.
Paulie
07-17-2004 05:24:45
 Re: Re: Re: Re: HOW SHOULD I WASH PARTS? in reply to CNKS, 07-07-2004 17:45:40
You have stated that gasoline may leave a residue on the parts and I was wondering if a lacquer thinner would also leave a residue ?
I was thinking that the lacquer thinner may be better but then I may be incorrect. Thanks !
