CN, With a pressure-fed setup there are two different pressures. One is the normal air pressure that provides atomizing air to the air cap. The other pressure is also air pressure but it has nothing to do with atomizing the paint and does not go to the air cap. It serves only to pressurize the paint in the cup, either attached below the gun similar to suction feed or remote from the gun with a remote cup arrangement. With either a suction or gravity feed gun, HVLP or not, the paint is under zero pressure - the cups are vented to the atmosphere. With pressure feed the cup (and paint in it) is under pressure, whether the cup is attached or remote. This pressure is provided by a separate regulator from the one suppling atomizing air. The paint is therefore forced to and through the fluid tip under pressure. It does not have to just flow by gravity or be sucked up a suction tube. With pressure feed, the atomizing air pressure for non-HVLP is, as you say, 40-60 psig at the gun inlet. The fluid (paint) pressure is the pressure in the cup and is separately adjustable. Typically this fluid pressure will be between 5 and 15 psig, depending on fluid tip size and paint viscosity. Here's my pressure-fed remote cup arrangement:
 The air from my wall regulator goes in the quick coupler nipple shown. From there it goes to two things. One is the atomizing air to the gun via the red hose. At the gun end of the red (air) hose is my inlet pressure gage, PG 1. I set my wall regulator to whatever will give me the 40-60 psig on this gage. I usually like to go for the high end, nearer 60 since I like a fairly high rate of paint flow and need a little more atomization air. The second path for the air is to the regulator for the fluid pressure, REG 1 shown. This regulator is set to establish the paint pressure in the cup, shown at PG 2. I usually set it about 10 psig, closer to 15 psig for a surfacer. The paint is forced under pressure through the black fluid hose to the fluid tip in the gun. There is very little air flow through through REG 1 - only that amount that is required to maintain the cup pressure as the paint level drops during use. I have absolutely no idea what the actual air cap pressure is for the atomizing air. I am sure it is significantly higher, perhaps a lot higher than the 10 psig mandated by HVLP. The 10 psig HVLP requirement is "at the air cap". It is outside the fluid tip and not inside it. The actual pressure inside the fluid tip is slightly sub-atmospheric for a gravity feed gun and more so negative for a suction feed gun. A pressure feed gun on the other hand has a positive pressure inside the fluid tip. A lot more paint can be put through a small tip size under pressure than can be put through the same tip by gravity or suction. Think of it this way: an HVLP gravity gun usually has one air cap that is designed for a certain fan pattern with a single inlet air pressure and a constant paint flow in oz/min. Materials of different viscosity are accommodated by changing fluid tip and needle sizes in order to get a similar oz/min of paint flow. A pressure feed can use different air caps for different fan patterns, different paint pressures, different air atomizing pressures and can accomodate most automotive paint viscosities with a single, relatively small fluid tip and needle assembly. Yes, the PPG P-sheets (both OMNI and premium lines) do not indicate any pressure feed information. I suspect it's because that type of arrangement is not popular in body shops although I would think fleet painters would love it. There are also less variables to deal with on a gravity feed HVLP setup so compliance with the law would be easier. Interestingly, the DuPont P-sheets for the various mixes of Centari acrylic enamel indicate that a pressure pot (pressure feed) is actually the recommended mode but do not give any setting information. The only pressure info they give is for a siphon gun (suction feed). I suppose that is understandable since putting "8-10 psi at the cap" for a HVLP gun really serves no useful purpose in a paint spec sheet and could add to confusion...the user has no realistic way to measure it and has to depend on the gun manufacturer to provide the correct gun inlet pressure for legal compliance. With two air pressure regulators, one for atomizing air and the other for pressurizing the paint, there can be somewhat different settings between them to accomplish the same thing. If I increase the paint pressure in the cup I will be flowing more oz/min of paint through the fluid tip. To properly atomize the greater amount of paint, I will also need to increase my atomizing air pressure. Rather than attempting to provide specific settings in a paint spec, I would guess these settings would be best determined in the field for each individual's situation. I usually start with a fixed atomizing air pressure and increase the paint pressure until there is a nice full pattern with good atomization. The setting will also change if a different air cap is selected in order to provide a larger fan pattern (more paint flow required). I hope this explains it. It's a real blast to paint with this arrangement although it is not appropriate for small items that can be done with a spot gun. The biggest down side is that it is a PITA to clean. Not only do you have the gun and cup as separate and distinct pieces but you also have to flush out the black fluid (paint) hose. Plus it is more complicated to adjust the two different pressures correctly. I don't know exactly what gun arrangement Paul has. Apparently it is a pressure fed gun or at least is capable of being pressure fed. Pressure fed guns with attached cups are usually also suction feed guns. Mine originally came with a suction cup but I replaced it with a remote one. In other words, you can use the gun either as a suction feed gun or as a pressure feed gun but you would usually have to change fluid tips and needles to accomodate the mode selected. At least I had to. I have never seen a combination pressure feed/gravity feed gun but they may exist. It is certainly possible to do given the right pieces. If he is actually pressure-feeding the gun, the 1.3 tip may be too big for the 182 depending on his air cap and fan pattern. In other words he may be flowing more paint than his air cap is designed to atomize properly. There should be charts that came with his gun for some guidance in setting it up in different modes for different viscosity materials. Didn't mean to write a book here but I get carried away easily :o).
