Laquer over enamel
Jim K
07-16-2004 16:28:01
I have to paint a part that is made out of fiberglass and I have to spray a laquer paint over an enamel, is there a primer that is compatable with enamel and laquer, or do I have to strip this thing.
thanks in advance Jim K
Rod (NH)
07-17-2004 16:55:37
 Re: Laquer over enamel in reply to Jim K, 07-16-2004 16:28:01
Hi Jim,
You should not have a problem as long as the enamel is fully cured. That could mean several months after initial dry if it is a refinish enamel, unless you know for sure it was originally used with a hardener. You should be able to just scuff the surface with 400 grit to cut any gloss and provide a "tooth" for adhesion of the topcoat. You could then apply the lacquer directly. third party image Rod
