Hi Jim, There is no reason to apologize for anything and no reason for either myself or CNKS to be upset about anything. There are differences of opinion on any subject, including the hazards of isocyanates. We have been expressing our opinions based upon our own past experiences, taken together with published industry standards and guidance. Others can and do feel differently. Different people are affected in different ways by isos and some seem not to be affected much at all. The preponderance of evidence over many years however, is that these specific chemicals are especially hazardous to one's health and that extra precautions should be taken when using them. There are those that argue that a standard chemical cartridge mask can provide adequate protection against isos if used properly. While that may be true, most would rightfully advise against it because of unknown individual tolerance levels, undetermined exposure levels and uncontrolled variables involved with such a practice. Remember that isocyanates are only present in the hardeners used as an optional additive in enamels and as a required additive in all the 2-part urethane paints. Standard synthetic and acrylic enamels do not contain such chemicals by themselves and can be used safely with a regular chemical cartridge mask. That is not to say the standard paints are good to breathe. They are not. There is bad "stuff" in all paints. It is just that the risk to health is significantly less w/o isos and filtration through a cartridge, even if not perfect, can provide adequate protection. If one is not in the employ of others where there are legal and work related requirements for fresh air respirators when using isos, the decision to get by with only filtration cartridges is entirely up to the individual. Those that ignore the printed safety instructions on the products they use do so at their own risk however. See the fine print on any hardener can label. Sooo...if you want to avoid isocyanates altogether or the risk of using them w/o a fresh air respirator you are left with the following options, IMO: 1. Rattle can paint - both enamel and lacquer versions 2. Synthetic (alkyd) enamels w/o hardeners - these are the typical "tractor store" and hardware store enamel paints 3. Acrylic enamels w/o hardeners - there are some decent automotive paints in this category such as DuPont's Centari and PPG's OMNI MAE (also PPG's Delstar if you can find it). Martin Senour (NAPA) also has, I think, a competitive line of enamels that do not require an iso additive. Any of the above can produce a result that looks very nice indeed. Not Mercedes quality, to be sure. But nice nevertheless. At least for a while. They all will provide decent protection for the metal. The synthetics should be as good as the OEM paint, at least that used on vintage tractors. The acrylics will be a little better and usually will also carry a higher price. Where they all fall short is in long term gloss retention, fade and chemical spill resistance and questionable near term repair capability, compared to hardened enamels and urethanes. Keeping the vehicles shedded when not in use and avoiding gasoline spills can minimize these shortfalls. That's the "price" one has to pay to avoid isocyanates in modern paints. It was good enough years ago before isos were developed and it can be good enough today if one doesn't expect '90's urethane performance from '50's synthetic enamels. Rod
