I am getting ready for my first ever BC/CC project. It is a replacement front bumper for my wife's 2000 Honda - bright red. I decided to use base/clear because I wanted as good a match as possible with the existing OEM base/clear finish on the car.I am generally a fan of the PPG OMNI line of economical automotive paints but I have heard many complaints about how inferior their basecoat (MBC) is. I have found the single stage OMNI urethane MTK to be very good but I was concerned about the MBC since I had never used it. I decided to do a comparison test sprayout of both the OMNI MBC and PPG's auto refinish standby - a basecoat in the premium Deltron line known as DBU. I purchased a quart each (minimum buy) from the same store and mixed by the same counter person. My test sprayouts were about 3 or 4 square feet each on vertical sheetmetal panels. Both had a catalyzed jet black base (from previous sprayouts :o)). Both paints were cleared with OMNI MC161 urethane clear. Both the MBC and the DBU sprayed well but I noticed that the MBC was noticeably thinner even though it was not reduced as much as the DBU. I wound up using 4 coats of the MBC but three would probably have been satisfactory. I used 3 coats of the DBU but two probably would have been satisfactory. My conclusion is that an extra coat of MBC is needed to obtain coverage similar to the more expensive DBU. I had heard of people using six or more coats of the MBC to cover but I found no need for that many with red on black. Here's a cost comparison of OMNI MBC to PPG DBU in bright red: Basis for comparison: Same gun. Same assumed area covered (1/2 qt RTS req'd per coat). Full credit taken for unused reducer . Full credit also taken for unused/unmixed DBU. Basecoat only - no clear considered. MBC = $21.41/qt MR187 reducer = $14.27/gal Mix = 1:1 21.41 + 14.27/4 = $24.97 for 2 qts RTS 1/2 qt RTS/coat x 4 coats = 2 qts RTS required = $24.97 total (no MBC left over) DBU = $87.90/qt DRR1185 reducer = $37.20/gal Mix = 1:1.5 1/2 qt RTS/coat x 3 coats = 1.5 qts RTS required 0.6 qts DBU + 0.9 qts DRR = 1.5 qts RTS 87.90x0.6 + 37.20x0.9/4 = $61.11 total (0.4 qts DBU left over) DBU:MBC = 61.11/24.97 = 2.45 Therefore, the PPG DBU costs about 2-1/2 times as much as the OMNI MBC. This comparison favors the DBU since it takes credit for the left over unmixed DBU color and presumes that it can be used effectively later. If that is not the case, then the left over DBU should be considered waste. The DBU would then cost over 3-1/2 times as much as the MBC to properly cover the same area. Can one justify the extra cost for the DBU based on using less material to cover the same area? I think not, considering the above. The overall "quality" appearance of both paints is essentially the same. However, I concluded that the color match with the OEM paint is better with the DBU than the MBC. If matching existing panels well is an important criteria, then the extra cost appears justified. I will definitely do the bumper with DBU. For overalls though, you would not be able to tell the difference unless one was parked right next to the other. For complete jobs, like tractors, I would not spend the significant extra for the premium basecoat. Another factor that might tip the scales in favor of the DBU would be a significantly better long term durability. I don't know about that but would be surprised if there was a major difference. They are both cleared with a urethane. Perhaps a premium PPG clear would be more appropriate long term but that would make the cost difference even greater. In any event, as Dozerboss has noted, even the OEM clears have a nasty tendency to peel away after about 8 or ten years - at least for vehicles not shedded. I know, since I have had three of 'em that did that. When that happens, a complete repaint is really the only fix. Comments or criticism welcome. Rod
