Air compressor tank
Tom in St. Loui
08-02-2004 13:30:03
I inherited a Craftsman air compressor without an air tank. I have tried looking around for a tank but can't find any except the small carry around tanks.
Any body know where I can get an air tank with wheels and all the tank connections? Thanks.
Rod (NH)
08-03-2004 11:31:51
 Re: Air compressor tank in reply to Tom in St. Louis, 08-02-2004 13:30:03
Hi Tom,
Grainger's has some. I recommend only a coded, ASME tank. Make sure that whatever you get is properly rated for the maximum pressure your compressor will run at. You will also need to obtain a safety valve that is set no higher than the rated pressure (MAWP or maximum allowable working pressure) of the tank. If you don't already have it, you should have a pressure switch with the unloading feature that is commonly used, together with the necessary tank check valve.
third party image Rod
Jim Ulmer
08-02-2004 20:55:18
Try eBay. They seem to have tanks for sale frequently.
