ppg paint
Dale L
08-17-2004 16:39:49
does anyone know if PPG dx 1791/1792 is safe as an etch for omni mp170 epoxy primer?I know they are two different paint lines from the same manufacture. The paint man from napa says they are compatible but I,m a little leary. Any avice would be helpful. Thanks Dale L. from Mn.
CNKS
08-17-2004 18:04:12
 Re: ppg paint in reply to Dale L, 08-17-2004 16:39:49
The P-sheet doesn't list it. You can use 176. Why do you need an etch primer? On average, paint salesmen are one of the poorest sources of information, particularly where paint is not a major part of their business. The spec sheets are the only reliable source.
Dale L
08-17-2004 18:59:03
 Re: ppg paint in reply to CNKS, 08-17-2004 18:04:12
I have a few sheet metal part on the tractor I'm painting.Do I need to use a etch on sheet metal, I'm painting a Farmall H I hope to get some parts painted this week end.
Dale L.
08-18-2004 17:40:18
 Re: ppg paint in reply to Dale L, 08-17-2004 18:59:03
Most all the parts will be bare metal either by a wire brush or bead blasting. Do you think MP170 epoxy primer is good enough?
Dale L
08-19-2004 20:16:33
 Re: ppg paint in reply to Dale L., 08-18-2004 17:40:18
Can I use picklex under Omni170 and is it necassary? Also where do I find it
CNKS
08-19-2004 18:08:16
I have never blasted -- wire brushes leave sheet metal too smooth, far as I'm concerned, so I sand the sheet metal. I use Picklex 20 on everything, which I assume etches the cast enough to supplement my wire brushing. Cast does not sand well. There is some question whether phosphoric acid products should be used on cast since it is pourous -- I have had no problem that I am aware of.
CNKS
08-18-2004 17:32:37
You have to sand them anyway, sanding takes the place of etch.
CNKS
08-17-2004 18:06:33
I tried to post a link, I'll try again.
