Painting over rust
crazyman
01-18-2002 06:20:12
I have some old rusty farm implements (mowers, Hand plows, disc, Ect.) do I have to take them back to bare metal before painting? or can I paint over the rust? I have been told there is a rust stopper in the paint, and it is suppose to stop the rust from spreading. if so how does it work?
david
01-23-2002 12:02:04
 Re: painting over rust in reply to crazyman, 01-18-2002 06:20:12
Gempler's has a product sold as "Rust Converter" for $35 or so a gallon. It works very well on "sealing in the rust". We paint 50 or so pieces a semester in our shop. If someone wants a smooth surface then sand blast to bare metal. If they want a servicable paint job wire brush in an air drill and tehn paint with converter. Then prime and paint (you can use the converter as the primer but I like a primer coat in there. Check out Gempler's web site.
Eric
01-20-2002 22:49:56
There's a product called Rust Destroyer that has the rust converter built right into a red paint primer. We've been selling it for 15 years and it really does what it says. It's not cheap..about $43 per gallon but that a lot cheaper than the time and labor you might go through to take all the rust off first. You apply it right over tightly adhered rust and then paint over it with a quality implement enamel. Look at the site I included here and you can read about it. Check under "products" and then click on "primers"
Good luck
t
02-19-2002 07:42:40
 Re: Re: painting over rust in reply to Eric, 01-20-2002 22:49:56
fhjhhhty
steve
01-18-2002 20:01:34
i use an air wire brush to get 90% of the stuff off. all the loose stuff is gone, just "red metal" left. get a red oxide primer, brush on, from hardware or farm store. put on a good coat. let it dry for a week. I then put on a coat of finish enamel, quality depends on how shinny and long lasting you want. I have spray finished with automotive enamel that cost $200 gallon and it looks excellent and lasts for years, very shinny if you add hardener. for old farm implements, i get a gallon of tractor enamel at the farm store for $25.
steve
01-18-2002 20:00:18
Bill VanHooser
01-18-2002 15:33:12
I have not used it before, but a lot of people like rust converter that you can get at NAPA. Another option is to use Phosphoric Acid. This converts the rust to Iron Phosphate, which is a primer..... Bill
crazyman
01-19-2002 23:04:15
 Re: Re: painting over rust in reply to Bill VanHooser, 01-18-2002 15:33:12
where can I get the acid? and how much does it cost? I have about 8 old mowers, and 10 hand plows, and 5 rakes that I would like to restore.
hay
01-18-2002 09:33:45
if you want the paint to stay on the implements longer then you will have to make the surface clean and use a good primer and then paint. some paints claim they can stop rust, but i have never seen it happen.
