Epoxy Primer Caution!
Rod (NH)
08-19-2004 18:30:41
As one of the several proponents of epoxy primer on this forum, I thought I would pass along some information I ran across. Apparently all automotive epoxy primers are not the same. See this post in another forum on one person's poor experience with a Valspar epoxy primer. Also, please read Len Stuart's reply to the post. I am very surprised about the problem the guy is having and even more so with Valspar's apparent verbal response to him. I notice that the Valspar website does not link to any available written technical data sheets for any of their products so what they seem to be telling him cannot be verified by on-line information from the company.
I am not familiar with Valspar products and am not trying to dump on them but their apparent statement is just wrong that all epoxy primers, no matter the manufacturer, has a limitation like theirs. Their product is apparently different from similar epoxies from other major automotive paint companies and therefore some caution should be exercised when using it. To me this points up the importance of obtaining the manufacturer's published technical data sheet(s) for each product to determine what limitations may apply to it. No data sheet available? Then no sale. Period. Talk is cheap -- written documentation is far more reliable.
My own experience is with PPG's DP & DPLF epoxy primer and with their OMNI MP 170 epoxy primer. These products can, indeed be used over an etch primer or chemically etched steel -- in fact is it so stated that such surface pre-treatments are an acceptable substrate in the applicable tech sheets. I have used the DP very successfully many times over chemically etched steel so Valspar just doesn't know what it's talking about regarding PPG's epoxy. I am sure PPG would say the same :o).
third party image Rod
Big Jim
08-19-2004 20:13:53
 Re: Epoxy Primer Caution! in reply to Rod (NH), 08-19-2004 18:30:41
Once again, product compatability rears it's ugly head. Picklex is a common product but is isn't made by Valspar so there is no certainty of compatability. Looking around Valspar's web site, I find they make a Sunlock II 88 etching primer/pretreatment. Wanna bet that, if he'd used that, his Valspar primer would have stuck like glue?
I admit to being a little curious about how he spent $800 on 2 coats of primer.
JMD
08-20-2004 16:02:39
 Re: Epoxy Primer Caution! in reply to Big Jim, 08-19-2004 20:13:53
$800.00 includes all my materials not just the two gallons of paint. As for the 88 sunlock, it specifically says on their data sheet do not apply VP series epoxy primer over 88 sunlock. I have a meeting with the supplier Monday morning to try and rectify this. I told them I was using pickle x and that I wanted to use omni for my color and this is what they recommended. It has been a complete disaster.
Rod (NH)
08-20-2004 19:46:51
 Re: Epoxy Primer Caution! in reply to JMD, 08-20-2004 16:02:39
Marty, or Mike, or Duster, or JMD -- not sure if you are all one and the same :o);
Sorry to hear about your misfortune with Valspar's unusual "epoxy" primer that has "etch" properties. Unfortunately, I doubt you will get much satisfaction from Valspar as a company. If you have a tech sheet from them for the product you used and it states not to use it over their own etch primer then I think they are pretty much absolved of any liability. They certainly are not going to endorse using it over another manufacturer's product, even if there is no problem with it. That's a mixing and matching issue that is the responsibility of the individual user. The fact that someone may have verbally led you to believe you could use the primer over the picklex is just so much...blowing in the wind. Companies are generally not liable for any verbal information from their own employees -- and certainly not from distributor employees. It's what's in "authorized" writing that counts. The fact that other paint companies recommend their own epoxy over their own etch is not particularly relevant, IMO. The fact that a tech sheet from Valspar indicates not to use that primer over their own etch should have been a warning flag that there might be a problem with other similar products from other manufacturers. I take it that it was your material supplier (not Valspar company) that verbally recommended you use the Valspar primer over the picklex plus an OMNI topcoat. That being the case, perhaps the best you can hope for is that your supplier will feel guilty enough about the bum info to give you a free gallon on OMNI MP170 (w/catalyst) just to keep you as a customer. I doubt Valspar gives a you-know-what about it. Sorry to be so blunt but that is my take on the situation.
In any event, good luck on Monday getting as much satisfaction as possible.
CNKS
08-20-2004 17:28:58
JMD, if you used an "epoxy" primer with etching properties over Picklex 20, that is a no-no. Use one etching product or the other, but not both. If I have misinterpreted what you said, I apologize.
Duster
08-20-2004 04:50:08
Actually we have the Data sheet , and for this primer VP 50 it says NOT to use over valspars sunlock 88. So it would have not stuck like glue.
I really think they need to re-word the data sheet (not to use over any metal conditioners/rust converters) Which I think defies the proponents of an Epoxy primer.
From what we've been told by Valspar that this product is not really an epoxy but more of an etch. Valspar has been nothing but rude and unprofessional in trying to resolve the problem.
The paint supply house we are using is trying to help us out in some way, we have a meeting with them on Mon. So we'll see.
Thanks for all the responses.
Mike
Dozerboss
08-19-2004 21:05:07
I think he meant he was out $800 including stripping the car twice and the cost of paint. He may have paid to have it blasted or rented a paint booth or paid for some body work and is including the purhase of tools and paint guns for the job to end up with $800 spent on peeling primer thus far.
Valspar hardner is sold at tractor supply for their line of paint. Best Paint Made i believe is the brand. $30 a gallon so i don't equate them with automotive quality paints. I have seen wood varnish and boat bottom paint made by Valspar. I wonder why he choose Valspar in the first place? I think i will go over there and ask.
I have used OMNI MP 170 epoxy primer over chemically etched metal and zinc phosphate coatings left by rust remover with no problems. I concur.
Sounds like a bad product, like the peeling GM clear coats. Could it be they won't scrap the formula because they have spent $ to develop this paint?
Big Jim
08-19-2004 22:37:31
 Re: Epoxy Primer Caution! in reply to Dozerboss, 08-19-2004 21:05:07
I've never used Valspar but I have heard no-so- nice things about it. In terms of quality, I think it's right down there, maybe below, the Rayflex sold on eBay. Actually, Rayflex doesn't seem to be that bad for what it is but it is hard to work with.
Smoky
08-19-2004 23:27:28
 Re: Epoxy Primer Caution! in reply to Big Jim, 08-19-2004 22:37:31
It appears you are dumping on Valspar based on Tractor Supply products. Valspar is an old company with a full line of quality products besides those made to sell at a too low price. I have used their Marine products on occasion over the last 30 years and find them to be equal to Petit and other marine paints. You get what you pay for. I painted a boat last year with Valspar marine paint and hardener and it looks great and is holding it's gloss very well. Valspar is a major producer of paints and is selling and promoting their high end products under other names. You have probably used their products and not realized it. Enough said, I also pass on their paint for tractors. But the stuff is great for rusty old trailers and Equipment.
Dozerboss
08-20-2004 19:25:52
 Re: Epoxy Primer Caution! in reply to Smoky, 08-19-2004 23:27:28
Most of the ?'s on this board are from people who want to do the best possible job. Painting over rust on trailers and equipment isn't the quality most want.
Anyone who blasts, strips or wire brushes to bare metal has done a lot of hard work and spent a good sum on materials and equipment to get there. Products like picklex @ $40 a qt are made to preserve the metal until paint day so primer and top coat can be applied together within the time window for chemical bond to each other for the best adhesion possible. Anyone who has a paint failure after all this effort is going to be upset, rightfully so.
Based on what i have read on both boards, I'm concerned enough by the triple failure of one of Valspar's higher end products--The Epoxy Primer, not to use their product at this time. I still haven't gotten an answer on what properties the valspar epoxy has that made it the painters product of choice either.
I want to hear about products good and bad as well as techniques, tools and tips that may save me $ or labor.
Marine paints are a whole other world. A boat that is moored in fresh water in a cool climate will retain its finish longer than a boat moored in cool salt water. For bottom paints, What works well in cold salt water doesn't usually have half the performance in warm salt water, because of the thousands of critters that live and thrive in warm salt water just waiting to attach themselves to hulls, rudders and props. If you like their products, that's fine and if you feel they are being dumped on that's fine with me too. I think they need to be held accountable for product failures and any information they put out that is wrong or in their own self interest.
