Removing Bondo
GregH
08-21-2004 21:56:39
The lower hood panels (on each side of grille) on my 63 Ford 2000 have bondo in them. Whoever attempted the body work did a pretty lousy job. Is there anything that will soften the bondo so I can get back to just the sheet metal and rework it?
CNKS
08-22-2004 17:23:47
 Re: Removing Bondo in reply to GregH, 08-21-2004 21:56:39
A wire wheel will remove anything the paint stripper leaves.
Dozerboss
08-22-2004 20:03:50
 Re: Removing Bondo in reply to CNKS, 08-22-2004 17:23:47
Paint stripper will soften it in layers so you can take it off with a plastic scraper. Thats how i like to do it in case i slip, the plastic does no more harm. If you can't fit a wire wheel in there to get the residue, a heat gun is another method to soften it up. That works good on undercoating on cars too.
