Pickle x
Dale L
08-22-2004 07:42:04
Can pickle X be used under PPG's epoxy primers
CNKS
08-22-2004 09:25:08
 Re: Pickle x in reply to Dale L, 08-22-2004 07:42:04
Yes Picklex 20 can be used under epoxy primer. As stated earlier in another thread, I don't believe that it is a good idea to use both Picklex and ETCH primer, as there may be reactions between the two. EPOXY is ok. Picklex will leave a residue, the "dirtier" the metal, ie cast, the more residue. I usually remove most of it with scotchbrite pads. I don't know if this is necessary, but I don't like painting over anything but metal.
